viewtopic.php
Перед
Вставляем
Находим
После вставляем
viewtopic.tpl
Находим
Заменяем
lang_main.php
Перед
$template->assign_block_vars('postrow', array(
'ROW_CLASS' => !($i % 2) ? 'row1' : 'row2',
'POST_ID' => $postrow[$i]['post_id'],
'IS_NEWEST' => ($postrow[$i]['post_id'] == $newest),Вставляем
$u_up_release = $u_down_total = 0;
if ($postrow[$i]['user_id'] > 0) //проверка на бота
$sql = "select u_up_release, u_up_total FROM " . BT_USERS_TABLE . " WHERE user_id = " . $postrow[$i]['user_id'] ;
DB()->query($sql);
if ($row = DB()->fetch_row($sql)) // получаем скока юзер скачал и скока одтдал на своих(!)
$u_up_release = $row['u_up_release'];
$u_up_total = $row['u_up_total'];
@$u_rate = round(($u_up_total)/1024/1024/1024, 2) ;
if($u_rate < 5) //0GB+
{$poster_rank_spec = $lang['poster_ur1_rank_0'];}
if(($u_rate >= 5)&&($u_rate < 10)) //5GB+
{$poster_rank_spec = $lang['poster_ur1_rank_5'];}
if(($u_rate >= 10)&&($u_rate < 20)) //10GB+
{$poster_rank_spec = $lang['poster_ur1_rank_10'];}
if(($u_rate >= 20)&&($u_rate < 40)) //20GB+
{$poster_rank_spec = $lang['poster_ur1_rank_20'];}
if(($u_rate >= 40)&&($u_rate < 50)) //40GB+
{$poster_rank_spec = $lang['poster_ur1_rank_40'];}
if(($u_rate >= 50)&&($u_rate < 70)) //50GB+
{$poster_rank_spec = $lang['poster_ur1_rank_50'];}
if(($u_rate >= 70)&&($u_rate < 100)) //70GB+
{$poster_rank_spec = $lang['poster_ur1_rank_70'];}
if(($u_rate >= 100)&&($u_rate < 150)) //100GB+
{$poster_rank_spec = $lang['poster_ur1_rank_100'];}
if(($u_rate >= 150)&&($u_rate < 200)) //150GB+
{$poster_rank_spec = $lang['poster_ur1_rank_150'];}
if(($u_rate >= 200)) //200GB++++
{$poster_rank_spec = $lang['poster_ur1_rank_200'];}
}Находим
'POSTER_RANK' => $poster_rank,
После вставляем
'POSTER_RANK_SPECIAL'=> @$poster_rank_spec,
viewtopic.tpl
Находим
<p class="rank_txt">{postrow.POSTER_RANK}</p>Заменяем
<p class="rank_txt">{postrow.POSTER_RANK}</p><p class="rank_txt">{postrow.POSTER_RANK_SPECIAL}</p>lang_main.php
$lang['poster_ur1_rank_0'] = 'ЮЗЕР'; $lang['poster_ur1_rank_5'] = 'ПОСЕТИТЕЛЬ'; $lang['poster_ur1_rank_10']= 'РЯДОВОЙ'; $lang['poster_ur1_rank_20']= 'БЫВАЛЫЙ'; $lang['poster_ur1_rank_40']= 'МЕСТНЫЙ'; $lang['poster_ur1_rank_50']= 'МАСТЕР'; $lang['poster_ur1_rank_70']= 'ПОЧЁТНЫЙ'; $lang['poster_ur1_rank_100']= 'СУПЕР-СИД'; $lang['poster_ur1_rank_150']= 'ТОП-СИД'; $lang['poster_ur1_rank_200']= 'МЕГА-РЕЛИЗЕР';
