#31
Gemini_13, Благодарю! Заработало!
[18-Mar-2017 17:54:05 Europe/Helsinki] PHP Notice: Undefined index: avatar_filesize in /home/trekker/public_html/includes/ucp/register.php on line 35в ней
$humanizer_attribute = md5($bb_cfg['board_startdate'] + $bb_cfg['avatar_filesize'] * $bb_cfg['announce_interval']);а так работает и боты поубавились а то достали. спасибо за мод.
md5($bb_cfg['board_startdate'] + rand(1,999) * $bb_cfg['announce_interval']); - такого вполне хватит.А белый экран что означать может?означает, что нужно включить показ ошибок
* MIT License
* Copyright (c) 2005-2017 TorrentPier
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
if (!defined('BB_ROOT')) {
die(basename(__FILE__));
array_deep($_POST, 'trim');
set_die_append_msg();
if (IS_ADMIN) {
$bb_cfg['reg_email_activation'] = false;
$new_user = (int)request_var('admin', '');
if ($new_user) {
$gen_simple_header = true;
$template->assign_vars(array(
'NEW_USER' => $new_user,
$can_register = (IS_GUEST || IS_ADMIN);
$submit = !empty($_POST['submit']);
$errors = array();
$adm_edit = false; // редактирование админом чужого профиля
require INC_DIR . '/bbcode.php';
require INC_DIR . '/functions_validate.php';
require INC_DIR . '/functions_selects.php';
$pr_data = array(); // данные редактируемого либо регистрационного профиля
$db_data = array(); // данные для базы: регистрационные либо измененные данные юзера
$tp_data = array(); // данные для tpl
// Защита от авторегистрации ботов
if(!empty($_POST['num1']) && !empty($_POST['num2']) && !empty($_POST['postnum'])){
$num1=intval($_POST['num1']);
$num2=intval($_POST['num2']);
$isnum=$num1+$num2;
$postnum=intval($_POST['postnum']);
}else{
$isnum = 0;
$postnum = -1;
// The anti bots
$humanizer_attribute = md5($bb_cfg['board_startdate'] + rand(1,999) * $bb_cfg['announce_interval']);
$ruhuman = isset($_POST[$humanizer_attribute]) ? $_POST[$humanizer_attribute] : '';
$ruhuman = trim(htmlspecialchars($ruhuman));
// Данные профиля
switch ($mode) {
* Регистрация
case 'register':
if (!$can_register) {
redirect('index.php');
if (!IS_ADMIN) {
// Ограничение по ip
if ($bb_cfg['unique_ip']) {
if ($users = DB()->fetch_row("SELECT user_id, username FROM " . BB_USERS . " WHERE user_reg_ip = '" . USER_IP . "' LIMIT 1")) {
bb_die(sprintf($lang['ALREADY_REG_IP'], '<a href="' . PROFILE_URL . $users['user_id'] . '"><b>' . $users['username'] . '</b></a>', $bb_cfg['tech_admin_email']));
// Отключение регистрации
if ($bb_cfg['new_user_reg_disabled'] || ($bb_cfg['reg_email_activation'] && !$bb_cfg['emailer']['enabled'])) {
bb_die($lang['NEW_USER_REG_DISABLED']);
} // Ограничение по времени
elseif ($bb_cfg['new_user_reg_restricted']) {
if (in_array(date('G'), array(0, /*1,2,3,4,5,6,7,8,11,12,13,14,15,16,*/
17, 18, 19, 20, 21, 22, 23))) {
bb_die($lang['REGISTERED_IN_TIME']);
// field => can_edit
$profile_fields = array(
'username' => true,
'user_password' => true,
'user_email' => true,
'user_timezone' => true,
'user_lang' => true,
'user_opt' => true,
$pr_data = array(
'user_id' => GUEST_UID,
'username' => '',
'user_password' => '',
'user_email' => '',
'user_timezone' => $bb_cfg['board_timezone'],
'user_lang' => $bb_cfg['default_lang'],
'user_opt' => 0,
'avatar_ext_id' => 0,
break;
* Редактирование профиля
case 'editprofile':
if (IS_GUEST) {
login_redirect();
'user_active' => IS_ADMIN,
'username' => (IS_ADMIN || $bb_cfg['allow_namechange']),
'user_email' => true, // должен быть после user_password
'user_gender' => true,
'user_birthday' => true,
'user_opt' => true,
'avatar_ext_id' => true,
'user_icq' => true,
'user_skype' => true,
'user_twitter' => true,
'user_website' => true,
'user_from' => true,
'user_sig' => true,
'user_occ' => true,
'user_interests' => true,
'tpl_name' => true,
// Выбор профиля: для юзера свой, для админа любой
if (IS_ADMIN && !empty($_REQUEST['u'])) {
$pr_user_id = (int)$_REQUEST['u'];
$adm_edit = ($pr_user_id != $userdata['user_id']);
} else {
$pr_user_id = $userdata['user_id'];
$profile_fields_sql = implode(', ', array_keys($profile_fields));
$sql = "
SELECT
user_id,
user_rank,
user_level,
$profile_fields_sql
WHERE user_id = $pr_user_id
LIMIT 1
if (!$pr_data = DB()->fetch_row($sql)) {
bb_die($lang['PROFILE_NOT_FOUND']);
break;
default:
trigger_error("invalid mode: $mode", E_USER_ERROR);
// Captcha
$need_captcha = ($mode == 'register' && !IS_ADMIN && !$bb_cfg['captcha']['disabled']);
if ($submit) {
if ($need_captcha && !bb_captcha('check')) {
$errors[] = $lang['CAPTCHA_WRONG'];
$need_chekbot = ($mode == 'register' && !IS_ADMIN);
if ($submit && $postnum!=$isnum && $need_chekbot)
$errors[] = $lang['IS_SPAM_BOT'];
// Защита от авторегистрации ботов конец
if ($mode == 'register' && !IS_ADMIN && $submit)
if (empty($ruhuman))
$errors[] = $lang['ARE_U_HUMAN_WRONG'];
elseif (strpos(mb_strtolower($lang['HUMANIZER_ANSWERS'],"UTF-8"), mb_strtolower($ruhuman,"UTF-8"))===FALSE)
// Валидация данных
$cur_pass_valid = $adm_edit;
foreach ($profile_fields as $field => $can_edit) {
switch ($field) {
* Активация (edit, reg)
case 'user_active':
$active = isset($_POST['user_active']) ? (int)$_POST['user_active'] : $pr_data['user_active'];
if ($submit && $adm_edit) {
$pr_data['user_active'] = $active;
$db_data['user_active'] = $active;
break;
* Имя (edit, reg)
case 'username':
$username = !empty($_POST['username']) ? clean_username($_POST['username']) : $pr_data['username'];
if ($submit) {
$err = validate_username($username);
if (!$errors and $err && $mode == 'register') {
$errors[] = $err;
if ($can_edit && $username != $pr_data['username'] || $mode == 'register') {
$pr_data['username'] = $username;
$db_data['username'] = $username;
$tp_data['CAN_EDIT_USERNAME'] = $can_edit;
$tp_data['USERNAME'] = $pr_data['username'];
break;
* Пароль (edit, reg)
case 'user_password':
if ($submit) {
$cur_pass = (string)@$_POST['cur_pass'];
$new_pass = (string)@$_POST['new_pass'];
$cfm_pass = (string)@$_POST['cfm_pass'];
// пароль для гостя и при смене пароля юзером
if (!empty($new_pass)) {
if (mb_strlen($new_pass, 'UTF-8') > 20) {
$errors[] = sprintf($lang['CHOOSE_PASS_ERR_MAX'], 20);
} elseif (mb_strlen($new_pass, 'UTF-8') < 4) {
$errors[] = sprintf($lang['CHOOSE_PASS_ERR_MIN'], 4);
} elseif ($new_pass != $cfm_pass) {
$errors[] = $lang['CHOOSE_PASS_ERR'];
$db_data['user_password'] = md5(md5($new_pass));
if ($mode == 'register') {
if (empty($new_pass)) {
$errors[] = $lang['CHOOSE_PASS'];
} else {
if (!empty($cur_pass)) {
$cur_pass_valid = ($pr_data['user_password'] === md5(md5($cur_pass)));
if (!empty($new_pass) && !$cur_pass_valid) {
$errors[] = $lang['CHOOSE_PASS_FAILED'];
break;
* E-mail (edit, reg)
case 'user_email':
$email = !empty($_POST['user_email']) ? (string)$_POST['user_email'] : $pr_data['user_email'];
if ($submit) {
if (empty($email)) {
$errors[] = $lang['CHOOSE_E_MAIL'];
if (!$errors and $err = validate_email($email)) {
$errors[] = $err;
$db_data['user_email'] = $email;
} elseif ($email != $pr_data['user_email']) {
// если смена мейла юзером
if (!$cur_pass_valid) {
$errors[] = $lang['CONFIRM_PASSWORD_EXPLAIN'];
$errors[] = $err;
if ($bb_cfg['reg_email_activation']) {
$pr_data['user_active'] = 0;
$db_data['user_active'] = 0;
$tp_data['USER_EMAIL'] = htmlCHR($email);
break;
* Язык (edit, reg)
case 'user_lang':
$user_lang = isset($_POST['user_lang']) ? (string)$_POST['user_lang'] : $pr_data['user_lang'];
if ($submit && ($user_lang != $pr_data['user_lang'] || $mode == 'register')) {
$pr_data['user_lang'] = $user_lang;
$db_data['user_lang'] = $user_lang;
break;
* Часовой пояс (edit, reg)
case 'user_timezone':
$user_timezone = isset($_POST['user_timezone']) ? (int)$_POST['user_timezone'] : $pr_data['user_timezone'];
if ($submit && ($user_timezone != $pr_data['user_timezone'] || $mode == 'register')) {
if (isset($lang['TZ'][$user_timezone])) {
$pr_data['user_timezone'] = $user_timezone;
$db_data['user_timezone'] = $user_timezone;
break;
* Пол (edit, reg)
case 'user_gender':
$user_gender = isset($_POST['user_gender']) ? (int)$_POST['user_gender'] : $pr_data['user_gender'];
if ($submit && $user_gender != $pr_data['user_gender']) {
$pr_data['user_gender'] = $user_gender;
$db_data['user_gender'] = $user_gender;
$tp_data['USER_GENDER'] = build_select('user_gender', array_flip($lang['GENDER_SELECT']), $pr_data['user_gender']);
break;
* Возраст (edit)
case 'user_birthday':
$user_birthday = !empty($_POST['user_birthday']) ? (string)$_POST['user_birthday'] : $pr_data['user_birthday'];
if ($submit && $user_birthday !== $pr_data['user_birthday']) {
$birthday_date = date_parse($user_birthday);
if (!empty($birthday_date['year'])) {
if (strtotime($user_birthday) >= TIMENOW) {
$errors[] = $lang['WRONG_BIRTHDAY_FORMAT'];
} elseif (bb_date(TIMENOW, 'Y', false) - $birthday_date['year'] > $bb_cfg['birthday_max_age']) {
$errors[] = sprintf($lang['BIRTHDAY_TO_HIGH'], $bb_cfg['birthday_max_age']);
} elseif (bb_date(TIMENOW, 'Y', false) - $birthday_date['year'] < $bb_cfg['birthday_min_age']) {
$errors[] = sprintf($lang['BIRTHDAY_TO_LOW'], $bb_cfg['birthday_min_age']);
$pr_data['user_birthday'] = $db_data['user_birthday'] = !empty($user_birthday) ? $user_birthday : null;
$tp_data['USER_BIRTHDAY'] = $pr_data['user_birthday'];
break;
* opt (edit)
case 'user_opt':
$user_opt = $pr_data['user_opt'];
$reg_mode = ($mode == 'register');
$update_user_opt = array(
# 'user_opt_name' => ($reg_mode) ? #reg_value : #in_login_change
'user_viewemail' => ($reg_mode) ? false : true,
'user_viewonline' => ($reg_mode) ? false : true,
'user_notify' => ($reg_mode) ? true : true,
'user_notify_pm' => ($reg_mode) ? true : true,
'user_porn_forums' => ($reg_mode) ? false : true,
'user_dls' => ($reg_mode) ? false : true,
'user_callseed' => ($reg_mode) ? true : true,
'user_retracker' => ($reg_mode) ? true : true,
foreach ($update_user_opt as $opt => $can_change_opt) {
if ($submit && (isset($_POST[$opt]) && $can_change_opt || $reg_mode)) {
$change_opt = ($reg_mode) ? $can_change_opt : !empty($_POST[$opt]);
setbit($user_opt, $bf['user_opt'][$opt], $change_opt);
$tp_data[strtoupper($opt)] = bf($user_opt, 'user_opt', $opt);
if ($submit && ($user_opt != $pr_data['user_opt'] || $reg_mode)) {
$pr_data['user_opt'] = $user_opt;
$db_data['user_opt'] = (int)$user_opt;
break;
* Avatar (edit)
case 'avatar_ext_id':
if ($submit && !bf($pr_data['user_opt'], 'user_opt', 'dis_avatar')) {
if (isset($_POST['delete_avatar'])) {
delete_avatar($pr_data['user_id'], $pr_data['avatar_ext_id']);
$pr_data['avatar_ext_id'] = 0;
$db_data['avatar_ext_id'] = 0;
} elseif (!empty($_FILES['avatar']['name']) && $bb_cfg['avatars']['up_allowed']) {
$upload = new TorrentPier\Legacy\Common\Upload();
if ($upload->init($bb_cfg['avatars'], $_FILES['avatar']) and $upload->store('avatar', $pr_data)) {
$pr_data['avatar_ext_id'] = $upload->file_ext_id;
$db_data['avatar_ext_id'] = (int)$upload->file_ext_id;
} else {
$errors = array_merge($errors, $upload->errors);
$tp_data['AVATARS_MAX_SIZE'] = humn_size($bb_cfg['avatars']['max_size']);
break;
* ICQ (edit)
case 'user_icq':
$icq = isset($_POST['user_icq']) ? (string)$_POST['user_icq'] : $pr_data['user_icq'];
if ($submit && $icq != $pr_data['user_icq']) {
if ($icq == '' || preg_match('#^\d{6,15}$#', $icq)) {
$pr_data['user_icq'] = $icq;
$db_data['user_icq'] = (string)$icq;
} else {
$pr_data['user_icq'] = '';
$errors[] = htmlCHR($lang['ICQ_ERROR']);
$tp_data['USER_ICQ'] = $pr_data['user_icq'];
break;
* Сайт (edit)
case 'user_website':
$website = isset($_POST['user_website']) ? (string)$_POST['user_website'] : $pr_data['user_website'];
$website = htmlCHR($website);
if ($submit && $website != $pr_data['user_website']) {
if ($website == '' || preg_match('#^https?://[\w\#!$%&~/.\-;:=,?@а-яА-Я\[\]+]+$#iu', $website)) {
$pr_data['user_website'] = $website;
$db_data['user_website'] = (string)$website;
} else {
$pr_data['user_website'] = '';
$errors[] = htmlCHR($lang['WEBSITE_ERROR']);
$tp_data['USER_WEBSITE'] = $pr_data['user_website'];
break;
* Откуда (edit)
case 'user_from':
$from = isset($_POST['user_from']) ? (string)$_POST['user_from'] : $pr_data['user_from'];
$from = htmlCHR($from);
if ($submit && $from != $pr_data['user_from']) {
$pr_data['user_from'] = $from;
$db_data['user_from'] = (string)$from;
$tp_data['USER_FROM'] = $pr_data['user_from'];
break;
* Подпись (edit)
case 'user_sig':
$sig = isset($_POST['user_sig']) ? (string)$_POST['user_sig'] : $pr_data['user_sig'];
if ($submit && $sig != $pr_data['user_sig']) {
$sig = prepare_message($sig);
if (mb_strlen($sig, 'UTF-8') > $bb_cfg['max_sig_chars']) {
$errors[] = $lang['SIGNATURE_TOO_LONG'];
} elseif (preg_match('#<(a|b|i|u|table|tr|td|img) #i', $sig) || preg_match('#(href|src|target|title)=#i', $sig)) {
$errors[] = $lang['SIGNATURE_ERROR_HTML'];
$pr_data['user_sig'] = $sig;
$db_data['user_sig'] = (string)$sig;
$tp_data['USER_SIG'] = $pr_data['user_sig'];
break;
* Род занятий (edit)
case 'user_occ':
$occ = isset($_POST['user_occ']) ? (string)$_POST['user_occ'] : $pr_data['user_occ'];
$occ = htmlCHR($occ);
if ($submit && $occ != $pr_data['user_occ']) {
$pr_data['user_occ'] = $occ;
$db_data['user_occ'] = (string)$occ;
$tp_data['USER_OCC'] = $pr_data['user_occ'];
break;
* Интересы
case 'user_interests':
$interests = isset($_POST['user_interests']) ? (string)$_POST['user_interests'] : $pr_data['user_interests'];
$interests = htmlCHR($interests);
if ($submit && $interests != $pr_data['user_interests']) {
$pr_data['user_interests'] = $interests;
$db_data['user_interests'] = (string)$interests;
$tp_data['USER_INTERESTS'] = $pr_data['user_interests'];
break;
* Skype
case 'user_skype':
$skype = isset($_POST['user_skype']) ? (string)$_POST['user_skype'] : $pr_data['user_skype'];
if ($submit && $skype != $pr_data['user_skype']) {
if ($skype != '' && !preg_match("#^[a-zA-Z0-9_.\-@,]{6,32}$#", $skype)) {
$errors[] = $lang['SKYPE_ERROR'];
$pr_data['user_skype'] = $skype;
$db_data['user_skype'] = (string)$skype;
$tp_data['USER_SKYPE'] = $pr_data['user_skype'];
break;
* Twitter
case 'user_twitter':
$twitter = isset($_POST['user_twitter']) ? (string)$_POST['user_twitter'] : $pr_data['user_twitter'];
if ($submit && $twitter != $pr_data['user_twitter']) {
if ($twitter != '' && !preg_match("#^[a-zA-Z0-9_]{1,15}$#", $twitter)) {
$errors[] = $lang['TWITTER_ERROR'];
$pr_data['user_twitter'] = $twitter;
$db_data['user_twitter'] = (string)$twitter;
$tp_data['USER_TWITTER'] = $pr_data['user_twitter'];
break;
* Выбор шаблона (edit)
case 'tpl_name':
$templates = isset($_POST['tpl_name']) ? (string)$_POST['tpl_name'] : $pr_data['tpl_name'];
$templates = htmlCHR($templates);
if ($submit && $templates != $pr_data['tpl_name']) {
$pr_data['tpl_name'] = $bb_cfg['tpl_name'];
$db_data['tpl_name'] = (string)$bb_cfg['tpl_name'];
foreach ($bb_cfg['templates'] as $folder => $name) {
if ($templates == $folder) {
$pr_data['tpl_name'] = $templates;
$db_data['tpl_name'] = (string)$templates;
$tp_data['TEMPLATES_SELECT'] = templates_select($pr_data['tpl_name'], 'tpl_name');
break;
* default
default:
trigger_error("invalid profile field: $field", E_USER_ERROR);
// submit
if ($submit && !$errors) {
* Создание нового профиля
$user_actkey = make_rand_str(12);
$db_data['user_actkey'] = $user_actkey;
} else {
$db_data['user_active'] = 1;
$db_data['user_actkey'] = '';
$db_data['user_regdate'] = TIMENOW;
$db_data['user_rank'] = 40;
if (!IS_ADMIN) {
$db_data['user_reg_ip'] = USER_IP;
if (!isset($db_data['tpl_name'])) {
$sql_args = DB()->build_array('INSERT', $db_data);
DB()->query("INSERT INTO " . BB_USERS . $sql_args);
$new_user_id = DB()->sql_nextid();
if (IS_ADMIN) {
set_pr_die_append_msg($new_user_id);
$message = $lang['ACCOUNT_ADDED'];
} else {
$message = $lang['ACCOUNT_INACTIVE'];
$email_subject = sprintf($lang['EMAILER_SUBJECT']['USER_WELCOME_INACTIVE'], $bb_cfg['sitename']);
$email_template = 'user_welcome_inactive';
} else {
$email_subject = sprintf($lang['EMAILER_SUBJECT']['USER_WELCOME'], $bb_cfg['sitename']);
$email_template = 'user_welcome';
/** @var TorrentPier\Legacy\Emailer() $emailer */
$emailer = new TorrentPier\Legacy\Emailer();
$emailer->set_from([$bb_cfg['board_email'] => $bb_cfg['sitename']]);
$emailer->set_to([$email => $username]);
$emailer->set_subject($email_subject);
$emailer->set_template($email_template, $user_lang);
$emailer->assign_vars(array(
'SITENAME' => $bb_cfg['sitename'],
'WELCOME_MSG' => sprintf($lang['WELCOME_SUBJECT'], $bb_cfg['sitename']),
'USERNAME' => html_entity_decode($username),
'PASSWORD' => $new_pass,
'U_ACTIVATE' => make_url('profile.php?mode=activate&' . POST_USERS_URL . '=' . $new_user_id . '&act_key=' . $db_data['user_actkey'])
$emailer->send();
bb_die($message);
* Редактирование
else {
set_pr_die_append_msg($pr_data['user_id']);
// если что-то было изменено
if ($db_data) {
if (!$pr_data['user_active']) {
$pr_data['user_actkey'] = $user_actkey;
$emailer->set_subject($subject);
$emailer->set_subject($lang['EMAILER_SUBJECT']['USER_ACTIVATE']);
$emailer->set_template('user_activate', $pr_data['user_lang']);
'U_ACTIVATE' => make_url("profile.php?mode=activate&u={$pr_data['user_id']}&act_key=$user_actkey"),
$emailer->send();
$message = $lang['PROFILE_UPDATED_INACTIVE'];
$user->session_end();
} else {
meta_refresh('index.php', 10);
$message = $lang['PROFILE_UPDATED'];
$sql_args = DB()->build_array('UPDATE', $db_data);
DB()->query("UPDATE " . BB_USERS . " SET $sql_args WHERE user_id = {$pr_data['user_id']}");
if ($pr_data['user_id'] != $userdata['user_id']) {
if ($pr_data['user_level'] == MOD && !empty($db_data['username'])) {
$datastore->update('moderators');
cache_rm_user_sessions($pr_data['user_id']);
if ($adm_edit) {
bb_die($lang['PROFILE_USER'] . ' <b>' . profile_url($pr_data) . '</b> ' . $lang['GOOD_UPDATE']);
} elseif (!$pr_data['user_active']) {
bb_die($lang['PROFILE_UPDATED_INACTIVE']);
} else {
bb_die($lang['PROFILE_UPDATED']);
} else {
bb_die($lang['NOTHING_HAS_CHANGED']);
$num1=intval(rand(1, 10));
$num2=intval(rand(1, 10));
$template->assign_vars($tp_data);
'PAGE_TITLE' => ($mode == 'editprofile') ? $lang['EDIT_PROFILE'] . ($adm_edit ? " :: {$pr_data['username']}" : '') : $lang['REGISTER'],
'SHOW_REG_AGREEMENT' => ($mode == 'register' && !IS_ADMIN),
'ERROR_MESSAGE' => ($errors) ? implode('<br />', array_unique($errors)) : '',
'MODE' => $mode,
'EDIT_PROFILE' => ($mode == 'editprofile'),
'ADM_EDIT' => $adm_edit,
'SHOW_PASS' => ($adm_edit || ($mode == 'register' && IS_ADMIN)),
'CAPTCHA_HTML' => ($need_captcha) ? bb_captcha('get') : '',
'LANGUAGE_SELECT' => language_select($pr_data['user_lang'], 'user_lang'),
'TIMEZONE_SELECT' => tz_select($pr_data['user_timezone'], 'user_timezone'),
'USER_TIMEZONE' => $pr_data['user_timezone'],
'AVATAR_EXPLAIN' => sprintf($lang['AVATAR_EXPLAIN'], $bb_cfg['avatars']['max_width'], $bb_cfg['avatars']['max_height'], (round($bb_cfg['avatars']['max_size'] / 1024))),
'AVATAR_DISALLOWED' => bf($pr_data['user_opt'], 'user_opt', 'dis_avatar'),
'AVATAR_DIS_EXPLAIN' => sprintf($lang['AVATAR_DISABLE'], $bb_cfg['terms_and_conditions_url']),
'AVATAR_IMG' => get_avatar($pr_data['user_id'], $pr_data['avatar_ext_id'], !bf($pr_data['user_opt'], 'user_opt', 'dis_avatar')),
'SIGNATURE_EXPLAIN' => sprintf($lang['SIGNATURE_EXPLAIN'], $bb_cfg['max_sig_chars']),
'SIG_DISALLOWED' => bf($pr_data['user_opt'], 'user_opt', 'dis_sig'),
'PR_USER_ID' => $pr_data['user_id'],
'U_RESET_AUTOLOGIN' => LOGIN_URL . "?logout=1&reset_autologin=1&sid={$userdata['session_id']}",
'NEED_CHEK_BOT' => $need_chekbot,
'NUM1' => $num1,
'NUM2' => $num2,
'ANTI_SPAM' => $lang['ANTI_SPAM'],
'MSG_ANTI_SPAM' => $lang['MSG_ANTI_SPAM'],
// The anti bots
'HUMANIZER'=> stripslashes($ruhuman),
'S_HUMANIZER_ATTRIBUTE' => $humanizer_attribute,
//dump($num1);
// The anti bots
$template->assign_block_vars('switch_register', array());
print_page('usercp_register.tpl');Не помню , что бы в этой теме задавал вопросы ...Значит я пошел делать )
Всё же вопрос есть : - Подходит ли эта инструкция на версию TorrentPier: Cattle (v2.4.4)
