При попытке скомпилировать xbtt на Centos выдает
При этом xbtt из SVN компилируется без проблем. Подскажите куда копать?
bash: ./make.sh:: No such file or directory [root@vps201 Tracker]# ./make.sh: line 17: tracker_input.cpp: command not found ./make.sh: line 18: transaction.cpp: command not found ./make.sh: line 19: udp_listen_socket.cpp: command not found ./make.sh: line 20: XBT Tracker.cpp: command not found ./make.sh: line 21: -rdynamic: command not found bash: ./make.sh:: No such file or directory [root@vps201 Tracker]# ./make.sh: line 18: transaction.cpp: command not found bash: ./make.sh:: No such file or directory [root@vps201 Tracker]# ./make.sh: line 19: udp_listen_socket.cpp: command not found bash: ./make.sh:: No such file or directory [root@vps201 Tracker]# ./make.sh: line 20: XBT Tracker.cpp: command not found bash: ./make.sh:: No such file or directory [root@vps201 Tracker]# ./make.sh: line 21: -rdynamic: command not found bash: ./make.sh:: No such file or directory
