Проблема XBT аннонсера closed
Started by XLex on 2011-06-29 08:40 — 49 replies, 13547 views
XANDER-CAGE,
Остается ждать ответа разработчиков...
root@***:/var/xbtt/linux/Tracker# ./xbt_tracker
Listen to 0.0.0.0 2710
Listen to :: 2710
Unknown column 'user_vip' in 'field list'
select bt.`user_id`, auth_key, case when bt.u_down_total>5368709120 and (bt.u_up_total+bt.u_up_bonus)<bt.u_down_total*0.3 then 0 else 1 end, case when bt.u_up_total>greatest(5368709120,bt.u_down_total) then 0 when bt.u_up_total>5368709120
XANDER-CAGE, обновляться не пробовал? http://code.google.com/p/torrentpier2/source/detail?r=187
_Xz_, только что выкачал из репы двиг, начал собирать xbtt и полезло кучу мата
root@***:/var/xbtt/Tracker# ./make.sh
: No such file or directory
g++: no input files
: command not founde.cpp: line 3:
: command not founde.cpp: line 7:
: command not founde.cpp: line 13:
'./misc/sql/database.cpp: line 14: syntax error near unexpected token `
'./misc/sql/database.cpp: line 14: `Cdatabase::Cdatabase()
: command not foundry.cpp: line 3:
: command not foundry.cpp: line 7:
../misc/sql/sql_query.cpp: line 8: syntax error near unexpected token `Cdatabase'
'./misc/sql/sql_query.cpp: line 8: `Csql_query::Csql_query(Cdatabase& database, const std::string& v):
: command not foundult.cpp: line 3:
../misc/sql/sql_result.cpp: line 4: syntax error near unexpected token `MYSQL_ROW'
../misc/sql/sql_result.cpp: line 4: `Csql_row::Csql_row(MYSQL_ROW data, unsigned long* sizes, const boost::shared_ptr<Csql_res'lt_source>& source)
: command not found: line 3:
: command not found: line 10:
: command not found: line 14:
../misc/bt_misc.cpp: line 15: syntax error near unexpected token `('
'./misc/bt_misc.cpp: line 15: `std::string escape_string(const std::string& v)
: command not found line 3:
: command not found line 7:
../misc/bvalue.cpp: line 8: syntax error near unexpected token `long'
'./misc/bvalue.cpp: line 8: `Cbvalue::Cbvalue(long long v)
: No such file or directory*
../misc/sha1.cpp: line 2: CMakeLists.txt: command not found
: command not foundine 3: *
../misc/sha1.cpp: line 4: CMakeLists.txt: command not found
../misc/sha1.cpp: line 5: CMakeLists.txt: command not found
../misc/sha1.cpp: line 6: CMakeLists.txt: command not found
: command not foundine 7: *
../misc/sha1.cpp: line 8: CMakeLists.txt: command not found
../misc/sha1.cpp: line 9: CMakeLists.txt: command not found
../misc/sha1.cpp: line 10: CMakeLists.txt: command not found
../misc/sha1.cpp: line 11: syntax error near unexpected token `('
'./misc/sha1.cpp: line 11: ` *      2**(n/2) to find any two messages with the same digest,
: command not found line 13:
../misc/socket.cpp: line 15: const: command not found
: command not found line 15:
: command not found line 17:
../misc/socket.cpp: line 19: const: command not found
: command not found line 19:
: command not found line 21:
../misc/socket.cpp: line 22: static: command not found
: command not found line 22:
: command not found line 23:
../misc/socket.cpp: line 24: syntax error near unexpected token `SOCKET'
'./misc/socket.cpp: line 24: `Csocket::Csocket(SOCKET s)
: command not foundary.cpp: line 3:
: command not foundary.cpp: line 7:
../misc/virtual_binary.cpp: line 8: syntax error near unexpected token `const_memory_range'
'./misc/virtual_binary.cpp: line 8: `Cvirtual_binary_source::Cvirtual_binary_source(const_memory_range d)
: command not foundline 3:
: command not foundline 8:
../misc/xcc_z.cpp: line 9: syntax error near unexpected token `('
'./misc/xcc_z.cpp: line 9: `Cvirtual_binary xcc_z::gunzip(const_memory_range s)
./make.sh: line 11: config.cpp: command not found
./make.sh: line 12: connection.cpp: command not found
./make.sh: line 13: epoll.cpp: command not found
./make.sh: line 14: server.cpp: command not found
./make.sh: line 15: tcp_listen_socket.cpp: command not found
./make.sh: line 16: tracker_input.cpp: command not found
./make.sh: line 17: transaction.cpp: command not found
./make.sh: line 18: udp_listen_socket.cpp: command not found
./make.sh: line 19: XBT Tracker.cpp: command not found
./make.sh: line 20: -Wl,-Bsymbolic-functions: command not found
XANDER-CAGE,
Именна эта ошибка была убрана в сборке, на которую я вам дал ссылку.
В misc boost и заголовочные файлы mysql кинули?
вот прям, только что вытянул файлы с вашего линка, залил на сервер, запускаю xbt все равно пишет что не хватает 'user_vip'. На счет boost не фига не понял, можно более понятней описать?
XANDER-CAGE,
Не с моего линка вытянули.
http://code.google.com/p/torrentpie...bt/linux/Tracker/server.cpp?spec=svn187&r=187 Нет здесь запроса к user_vip.
В папку misc скопировать папки boost и mysql. Если у вас фря, то они находятся в /usr/local/include/
#28
Mikotka, именно с Вашего, только что проверил все, размеры файлов совпадают.
#29
XANDER-CAGE,
Значит мистика. Т.к. я по моему линку не нахожу по Ctrl+F никаких vip 🙂
#30
Mikotka, Извиняюсь за наглость, вы не могли бы свои сорцы приаттачить?
