Проблема с первой страницей
Started by sergey67 on 2019-03-01 14:39 — 14 replies, 4179 views
http://dinozavr1967.ru/viewtopic.php?t=92&spmode=full , но ведь некоторые страницы открывает ...
Может так понятнее будет ???
Ну дак искать тут нужно /library/includes/datastore/build_stats.php в 55 линии
Ну и удалить все файлы /internal_data/cache/
Может табличка bb_users посыпалась ?
И что искать ???
* MIT License
* Copyright (c) 2005-2017 TorrentPier
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
if (!defined('BB_ROOT')) {
die(basename(__FILE__));
global $bb_cfg;
$data = array();
// usercount
$row = DB()->fetch_row("SELECT COUNT(*) AS usercount FROM " . BB_USERS . " WHERE user_id NOT IN(" . EXCLUDED_USERS . ")");
$data['usercount'] = number_format($row['usercount']);
// newestuser
$row = DB()->fetch_row("SELECT user_id, username, user_rank FROM " . BB_USERS . " WHERE user_active = 1 ORDER BY user_id DESC LIMIT 1");
$data['newestuser'] = $row;
// post/topic count
$row = DB()->fetch_row("SELECT SUM(forum_topics) AS topiccount, SUM(forum_posts) AS postcount FROM " . BB_FORUMS);
$data['postcount'] = number_format($row['postcount']);
$data['topiccount'] = number_format($row['topiccount']);
// Tracker stats
if ($bb_cfg['tor_stats']) {
// torrents stat
$row = DB()->fetch_row("SELECT COUNT(topic_id) AS torrentcount, SUM(size) AS size FROM " . BB_BT_TORRENTS);
$data['torrentcount'] = number_format($row['torrentcount']);
$data['size'] = $row['size'];
// peers stat
$row = DB()->fetch_row("SELECT SUM(seeders) AS seeders, SUM(leechers) AS leechers, ((SUM(speed_up) + SUM(speed_down))/2) AS speed FROM " . BB_BT_TRACKER_SNAP);
$data['seeders'] = number_format($row['seeders']);
$data['leechers'] = number_format($row['leechers']);
$data['peers'] = number_format($row['seeders'] + $row['leechers']);
$data['speed'] = $row['speed'];
// gender stat
if ($bb_cfg['gender']) {
$male = DB()->fetch_row("SELECT COUNT(user_id) AS male FROM " . BB_USERS . " WHERE user_gender = " . MALE . " AND user_id NOT IN(" . EXCLUDED_USERS . ")");
$female = DB()->fetch_row("SELECT COUNT(user_id) AS female FROM " . BB_USERS . " WHERE user_gender = " . FEMALE . " AND user_id NOT IN(" . EXCLUDED_USERS . ")");
$unselect = DB()->fetch_row("SELECT COUNT(user_id) AS unselect FROM " . BB_USERS . " WHERE user_gender = 0 AND user_id NOT IN(" . EXCLUDED_USERS . ")");
$data['male'] = $male['male'];
$data['female'] = $female['female'];
$data['unselect'] = $unselect['unselect'];
// birthday stat
if ($bb_cfg['birthday_check_day'] && $bb_cfg['birthday_enabled']) {
$sql = DB()->fetch_rowset("SELECT user_id, username, user_rank , user_birthday
AND user_birthday != '0000-00-00'
AND user_active = 1
ORDER BY user_level DESC, username
$date_today = bb_date(TIMENOW, 'md', false);
$date_forward = bb_date(TIMENOW + ($bb_cfg['birthday_check_day'] * 86400), 'md', false);
$birthday_today_list = $birthday_week_list = array();
foreach ($sql as $row) {
$user_birthday = date('md', strtotime($row['user_birthday']));
if ($user_birthday > $date_today && $user_birthday <= $date_forward) {
// user are having birthday within the next days
$birthday_week_list[] = array(
'user_id' => $row['user_id'],
'username' => $row['username'],
'user_rank' => $row['user_rank'],
'user_birthday' => $row['user_birthday'],
} elseif ($user_birthday == $date_today) {
//user have birthday today
$birthday_today_list[] = array(
$data['birthday_today_list'] = $birthday_today_list;
$data['birthday_week_list'] = $birthday_week_list;
$this->store('stats', $data);
* MIT License
* SOFTWARE.
global $bb_cfg;
$data = array();
// usercount
// newestuser
// post/topic count
// Tracker stats
// torrents stat
// peers stat
// gender stat
// birthday stat
AND user_active = 1
Я написал 3 пункта что делать ! Зачем мне код ?
С сайтом разобрался,были повреждены таблицы bb_bt_dlstatus_snap, bb_bt_last_torstat, bb_bt_last_userstat, bb_bt_tracker_snap. Их открыть было не возможно и забекапить тоже невозможно,т.к.содержимого не было,все строки были закоментированы в файле бекапа. Залил новые таблицы из коробки,сайт заработал. Появилась новая проблема:при запуске крон-задачи tr_seed_bonus.php вылазит ошибка A non-numeric value encountered на этой линии вот что
$tor_size = ($bb_cfg['seed_bonus_tor_size'] * 1073741824);
Как быть? Что делать?
