TorrentPier Cattle. Версия 2.4.0-rc1
Ссылка:
Release v2.4.0-rc1 · torrentpier/torrentpier
Чейнджлог:
Comparing v2.4.0-beta4...v2.4.0-rc1 · torrentpier/torrentpier
Основные изменения:
Ссылка:
Чейнджлог:
Основные изменения:
- Revert "Fix sql group (#128)" 1753db1 (belomaxorka)
- Simplified gender function #1167 (belomaxorka)
- Revert "Fixed input types in some cases (#697)" 20ce8ca (belomaxorka)
- Revert "Fixed input types in some cases (#693)" 74aa6ff (belomaxorka)
- Support simultaneous id & username inputs for browsing profiles #1166 (kovalensky)
- Tighten registration requirements for torrent files #1165 (kovalensky)
- File listing — use browser cache #1164 (kovalensky)
- Legacy code comment translations #1163 (kovalensky)
- Invites config re-formatting #1162 (belomaxorka)
- Use external cookie library to prevent incorrect cookie setting #1160, #1161 (belomaxorka)
- Some improvements in default template #1159 (belomaxorka)
- Use sent port instead of source #1158 (kovalensky)
- Remove unnecessary meta tags from file listing #1157 (kovalensky)
- Use different file listing url parameters for effective indexing by search engines #1156 (kovalensky)
- Check topic_id existence while searching in tracker mode #1155 (kovalensky)
- Some improvement #1151 (kovalensky)
- Disable invites by default #1150 (kovalensky)
- Event based invite system #1149 (kovalensky)
- Some code quality improvements #1148 (belomaxorka)
- Vote button code improvements #1140, #1142, #1143, #1146 (belomaxorka)
- Vote button and v2 file list topic url display #1138 (kovalensky)
- Removed topic watch useless code #1137 (belomaxorka)
- Fixed topic_watch array key name #1136 (belomaxorka)
- Fixed announce-list indexes ordering #1135 (belomaxorka)
- Fixed $bb_cfg['file_id_ext'] ordering #1134 (belomaxorka)
- Normalizing announce-list #1133 (belomaxorka)
- Fixed announcer-list issue #1129, #1130, #1131, #1132 (belomaxorka)
- Removed client column from bb_bt_tracker table #1128 (belomaxorka)
- Removed one-time used variables #1120 (belomaxorka)
- Don't create empty announce-list dict, if ann_urls are empty #1119 (kovalensky)
- Improve code for retracker addition #1118 (kovalensky)
- Don't use main announce url inside announce-list #1117 (kovalensky)
- Don't check for announce-list while adding new urls #1116 (kovalensky)
- Cleanup: Removed useless global variable #1115 (belomaxorka)
- Unset debug cookies if SQL_DEBUG disabled #1114 (belomaxorka)
- Announcer's code re-formatting #1112 (kovalensky)
- Used new-style [] array constructions in some cases #1111 (belomaxorka)
- Use http_response_code() functions instead of old header() functions #1110 (belomaxorka)
- Fix bypassing cache if IP changed while using cache #1109 (kovalensky)
- Use one variable to determine update status for hybrids #1108 (kovalensky)
- Don't re-announce even if peer cache is present #1107 (kovalensky)
- Used br2nl() in ajax alert messages #1106 (belomaxorka)
- Replaced some html_entity_decode to engine's built-in function #1105 (belomaxorka)
- Fix typo #1104, #1124, #1153, #1168 (kovalensky)
- Change default engine language to en #1103 (kovalensky)
- Record changed port while re-announcing #1102 (kovalensky)
- Translations for config.php, raised scrape interval #1100 (kovalensky)
- Don't re-announce for hybrids if the event is "stopped" #1099 (kovalensky)
- Security measures #1098, #1113 (kovalensky, belomaxorka)
- Minor improvements #1121, #1122, #1123, #1125, #1141 (belomaxorka)
- New Crowdin updates #1097, #1101, #1144, #1154 (Exileum)
Большое спасибо kovalensky ❤️
