TorrentPier Aurochs. Версия 2.2.0
Ссылка:
Release v2.2.0 · torrentpier/torrentpier · GitHub
Основные изменения:
Ссылка:
Основные изменения:
- Release preparation. Crowdin language pack update #322 (Exile37)
- TorrentPier Aurochs release preparation #321 (Exile37)
- Release preparation. Small bugfixes and readme translation #318 (Exile37)
- Crowdin language pack update #314 (Exile37)
- IP storage and attachment system bugfix. PHP 5.6+ #313 (Exile37)
- Bootstrap update & beginning of the develop branch partial merge #303 (Exile37)
- Fix avatars display bug #302 (Exile37)
- Cron subsystem rework. Environments #301 (Exile37)
- New logotype, favicon and css split & reformat #293 (Exile37)
- Whoops error handler for debug users #291 (Exile37)
- Replace sitemap to the new external component #252 (Exile37)
- Crowdin language pack update. Removed some languages #250 (Exile37)
- IP detect subsystem replace. Trash cleanup. Defines #249 (Exile37)
- Old ads module removal #244 (Exile37)
- External bencode library and some other changes #243 (Exile37)
- Added new logo to readme #242 (VasyOk)
- Bugsnag integration and some bugfixes in for cycles #239 (Exile37)
- Bug with variables replacement and Crowdin localization fix #238 (Exile37)
- PSR-4 compatible legacy code autoloading #237 (Exile37)
- UFT-8 autocorrection removal from standart package #236 (Exile37)
- New localization strings and full Crowdin language pack update #235 (Exile37)
- Replace own emailer to SwiftMailer #234 (Exile37)
- Force email charset and Crowdin language pack update #232 (Exile37)
- Crowdin language pack update #231 (Exile37)
- Static code analyzer inspection, part 2 #230 (Exile37)
- Static code analyzer cherry picked from #228 #229 (VasyOk)
- Fix compare php version. #226 (VasyOk)
- Fixed compare version PHP #225 (VasyOk)
- Deprecated each() function in php 7.2 #211 (Exile37)
- Performance refactoring. Remove test code. Fix path in config #208 (VasyOk)
- Fix many notices in admin_attach_cp.php #183 (Exile37)
- Add check lang #178 (VasyOk)
- Remove order from sql #177 (VasyOk)
- Fix path to viewtorrent.php #176 (VasyOk)
- New Crowdin translations #168 (Exile37)
- Localization trash cleanup #167 (Exile37)
- New Crowdin translations (develop) #165 (Exile37)
- New Crowdin translations (master) #164 (Exile37)
- Crowdin localization integration prepare and stopwords removal #163 (Exile37)
- Crowdin localization integration #162 (Exile37)
- New Crowdin translations (develop) #161 (Exile37)
- #157. Fix Error in GET /bt/announce.php #159 (VasyOk)
- Added check composer install #148 (VasyOk)
- Fix operators #147 (VasyOk)
- #144 Files should not be executable #145 (VasyOk)
- Change paths to absolute pathname #143 (VasyOk)
- Redundant pagination, mysql 5.7+ issue, release template option #141 (Exile37)
- Transfer announce to the php7-optimized database layer #140 (Exile37)
- Cleanup repository from old deprecated scripts and server configs #139 (Exile37)
- Torrent ajax file list fixes and small reformat #138 (Exile37)
- Codacy / Scrutinizer / Code Climate / Coveralls integration, Slack hook to Travis CI #137 (Exile37)
- Add a Codacy badge to README.md #136 (codacy-badger)
- Replace Sphinx API to the composer version #135 (Exile37)
- Incorrect case close operators (develop) #134 (Exile37)
- Incorrect case close operators (master) #133 (Exile37)
- Composer init, editor config, some cleanup and much more #132 (Exile37)
- Remove eval from admin_attachments and emailer #129 (VasyOk)
- Fix sql group #128 (VasyOk)
- Remove Zend #127 (VasyOk)
- Small fix to the upgrade schema #126 (Exile37)
- Fixed id sqllog table and name select db #125 (VasyOk)
- New external service for look up IP address #122 (Exile37)
- New branding and copyright #121 (Exile37)
- Poster birthday with no birthday date fix #120 (Exile37)
- Tidy deprecated option merge-spans remove #119 (Exile37)
- Db logging #118 (leroy0)
- CircleCi, CodeCoverage and composer dependencies #117 (Exile37)
- Db exceptions, query with binding #116 (leroy0)
- PHP 7+ requirements, Travis and other small fixes #115 (Exile37)
- New compatible with php7 classes: Db, Config #114 (Exile37)
- Refactoring posting_attachments #112 (VasyOk)
- Update the current year in the license text #110 (Exile37)
- Reformat master branch to PSR-2 and MIT license #109 (Exile37)
- Master branch up to php 7 compatibility #107 (VasyOk)
- Removal of unused scripts and server configs #105 (Exile37)
- New license - MIT #104 (Exile37)
- New coding standart: PSR-2 #103 (Exile37)
- Improvements in code and work cache #101 (VasyOk)
- Migration to the new config subsystem #100 (Exile37)
- php-lang-correct removed #99 (Exile37)
- Logical operators should be avoided #98 (Exile37)
- Migration to the new cache subsystem #97 (Exile37)
- Rework of feed.php and some other files #94 (Exile37)
- Refactoring Cache #92 (VasyOk)
- Add new tests and refactoring #89 (VasyOk)
- Add tests #88 (VasyOk)
- Some fix after removed @ #87 (VasyOk)
- #77 Add monolog #86 (VasyOk)
- Remove at #85 (VasyOk)
- Переделка файла dl.php на работу с новой базой #83 (Exile37)
- Added use profiler and in(de)crement methods. #82 (VasyOk)
- Remove response service provider #80 (VasyOk)
- DI usage example #79 (Exile37)
- Added methods to simplify the work with the database #75 (VasyOk)
- Captcha service provider #72 (Exile37)
- Fixed a getting value from config through method toArray #71 (VasyOk)
- #69 Fixed crypt notice #70 (VasyOk)
- #58 Expansion Zend Config #68 (VasyOk)
- change preset to prs2 #61 (VasyOk)
- Applied fixes from StyleCI #60 (Exile37)
UPDATE `bb_config` SET `config_value` = 'http://whatismyipaddress.com/ip/' WHERE `config_name` = 'whois_info';
DELETE FROM `bb_smilies` WHERE `code` = ':ad:';
INSERT INTO `bb_smilies` VALUES ('', ':сd:', 'сd.gif', 'сd');
DROP TABLE IF EXISTS `bb_ads`;
DELETE FROM `bb_config` WHERE `config_name` = 'active_ads';
ALTER TABLE `bb_log` DROP COLUMN `log_username`;
DELETE FROM `bb_config` WHERE `config_name` = 'new_tpls';
UPDATE `bb_posts` SET `poster_ip` = '0';
ALTER TABLE `bb_posts` CHANGE `poster_ip` `poster_ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_bt_tracker` SET `ip` = '0';
ALTER TABLE `bb_bt_tracker` CHANGE `ip` `ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_users` SET `user_last_ip` = '0';
ALTER TABLE `bb_users` CHANGE `user_last_ip` `user_last_ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_users` SET `user_reg_ip` = '0';
ALTER TABLE `bb_users` CHANGE `user_reg_ip` `user_reg_ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_log` SET `log_user_ip` = '0';
ALTER TABLE `bb_log` CHANGE `log_user_ip` `log_user_ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_poll_users` SET `vote_ip` = '0';
ALTER TABLE `bb_poll_users` CHANGE `vote_ip` `vote_ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_privmsgs` SET `privmsgs_ip` = '0';
ALTER TABLE `bb_privmsgs` CHANGE `privmsgs_ip` `privmsgs_ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_sessions` SET `session_ip` = '0';
ALTER TABLE `bb_sessions` CHANGE `session_ip` `session_ip` varchar(42) NOT NULL DEFAULT '0';
UPDATE `bb_banlist` SET `ban_ip` = '0';
ALTER TABLE `bb_banlist` CHANGE `ban_ip` `ban_ip` varchar(42) NOT NULL DEFAULT '0';
