Всем привет!
Пытаюсь скомпилировать аннонсер XBTT, но не получается =(
Вот эти ошибки:
ОС: FreeBSD 8.2
Пакеты boost-all и boost_build установлены.
Вот эти ошибки:
mypeer# ./make.bsd.sh In file included from connection.cpp:5: ../misc/bt_strings.h:115:68: warning: no newline at end of file In file included from server.cpp:10: ../misc/bt_strings.h:115:68: warning: no newline at end of file In file included from transaction.cpp:5: ../misc/bt_strings.h:115:68: warning: no newline at end of file In file included from ../misc/bt_torrent.cpp:4: ../misc/bt_strings.h:115:68: warning: no newline at end of file /var/tmp//cc6fHvhM.o(.text+0x10): In function `MD5::init()': : multiple definition of `MD5::init()' /var/tmp//cceHmfKN.o(.text+0x10): first defined here /var/tmp//cc6fHvhM.o(.text+0x50): In function `MD5::decode(unsigned int*, unsigned char const*, unsigned int)': : multiple definition of `MD5::decode(unsigned int*, unsigned char const*, unsigned int)' /var/tmp//cceHmfKN.o(.text+0x50): first defined here /var/tmp//cc6fHvhM.o(.text+0xa0): In function `MD5::encode(unsigned char*, unsigned int const*, unsigned int)': : multiple definition of `MD5::encode(unsigned char*, unsigned int const*, unsigned int)' /var/tmp//cceHmfKN.o(.text+0xa0): first defined here /var/tmp//cc6fHvhM.o(.text+0x810): In function `MD5::hexdigest() const': : multiple definition of `MD5::hexdigest() const' /var/tmp//cceHmfKN.o(.text+0x1d0): first defined here /var/tmp//cc6fHvhM.o(.text+0x1ef0): In function `MD5::MD5()': : multiple definition of `MD5::MD5()' /var/tmp//cceHmfKN.o(.text+0x3f0): first defined here /var/tmp//cc6fHvhM.o(.text+0x1f30): In function `MD5::MD5()': : multiple definition of `MD5::MD5()' /var/tmp//cceHmfKN.o(.text+0x430): first defined here /var/tmp//cc6fHvhM.o(.text+0x1f70): In function `MD5::transform(unsigned char const*)': : multiple definition of `MD5::transform(unsigned char const*)' /var/tmp//cceHmfKN.o(.text+0x470): first defined here /var/tmp//cc6fHvhM.o(.text+0x29e0): In function `MD5::update(unsigned char const*, unsigned int)': : multiple definition of `MD5::update(unsigned char const*, unsigned int)' /var/tmp//cceHmfKN.o(.text+0xee0): first defined here /var/tmp//cc6fHvhM.o(.text+0x2ab0): In function `MD5::update(char const*, unsigned int)': : multiple definition of `MD5::update(char const*, unsigned int)' /var/tmp//cceHmfKN.o(.text+0xfb0): first defined here /var/tmp//cc6fHvhM.o(.text+0x2ce0): In function `MD5::finalize()': : multiple definition of `MD5::finalize()' /var/tmp//cceHmfKN.o(.text+0xfc0): first defined here /var/tmp//cc6fHvhM.o(.text+0x2e20): In function `MD5::MD5(std::string const&)': : multiple definition of `MD5::MD5(std::string const&)' /var/tmp//cceHmfKN.o(.text+0x1100): first defined here /var/tmp//cc6fHvhM.o(.text+0x2e80): In function `MD5::MD5(std::string const&)': : multiple definition of `MD5::MD5(std::string const&)' /var/tmp//cceHmfKN.o(.text+0x1160): first defined here /var/tmp//cc6fHvhM.o(.text+0x3210): In function `md5(std::string)': : multiple definition of `md5(std::string)' /var/tmp//cceHmfKN.o(.text+0x11c0): first defined here /var/tmp//cc6fHvhM.o(.text+0x3490): In function `operator<<(std::ostream&, MD5)': : multiple definition of `operator<<(std::ostream&, MD5)' /var/tmp//cceHmfKN.o(.text+0x1440): first defined here /usr/bin/ld: Warning: size of symbol `_ZlsRSo3MD5' changed from 884 in /var/tmp//cceHmfKN.o to 580 in /var/tmp//cc6fHvhM.o
ОС: FreeBSD 8.2
