[English] Few Problems / Bugs
Started by Reitak on 2015-07-10 06:45 — 42 replies, 6570 views
@Reitak look through these links page_header.tpl and index_data.php and compare. If they are the same check your default timezone in php configuration.
string from link you give me and mine are same, i have latest TP 2.1.5.
my time 19:00 OK
server time 19:00 OK
php time 19:00 timezone Europe/Bratislava OK
phpmyadmin sql time 2015-07-13 19:00:05 OK
torrentpier unregistered user have topic 14:00 FAIL
torrentpier registered user have topic 21:00 FAIL
so there is bad time only on site torrentpier, all settings, timezones are OK
What time shows forum below online users block and your local time?
Current time is: 14-Jul *:*
when i setup in admin utc +1 what is europe/bratislava, then current time is 7:20, when i post on forum 9:20 , tried it setup to -2 but still 9:20, this is strange.
Date 14-Jul 09:20
Všetky časy sú v UTC + 2
@Reitak You set up global timezone for board in admin panel. But you have post using your personal timezone set automatically. When you change board timezone in admin panel you still see the time using your personal timezone, so that's alright
yes i know this, but how can i change timezone in profil, there is no option. but ! if it is possible, ok, i change it but in my profile, all guest have another time and all other registered another.
PS : another question, it is possible change counter / speed of refresh data speed download, leecher, seeder? because it takes too long when leecher show on stats, or topic of torrent.
@Reitak Have you disabled cron? Seems like you don't
You ought to disable cron and add execution of cron.php to system crontab on your server
#28
yes i have disabled cron in site and enabled on system from begin and have it every 1 min and that stats refresh i dont know every 4-5 min?
#29
heh .... i go to phpmyadmin, I and other users have there timezone 2.00 and quest 0.00
when i change timezone to 0.00 on my name, i refresh site, time is correct !! but when i refresh it again, again I have another time
#30
@Reitak Being opened at first time the board detects your local personal timezone and put it into database. After refresh the board begins using personal timezone. Why does the board detect UTC+2? It depends on your PC timezone
