Белый экран
Started by k1sher on 2015-02-05 14:22 — 3 replies, 1592 views
Загрузил трекер на хостинг. Пытаюсь на него зайти и просто ничего. Белый экран. В логах на хостинге нашел это.
[Thu Feb 05 17:04:36 2015] [error] [client 176.215.221.98:15864] AH01276: Cannot serve directory /home/w/wfb7902q/lifetor/public_html/styles/: No matching DirectoryIndex (index.shtml,index.html,index.php,index.htm) found, and server-generated directory index forbidden by Options directive
Хостеру пишите, проблема с его стороны.
Что может значить эта ошибка?
Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Moscow' for 'MSK/3.0/no DST' instead in /home/w/wfb7902q/lifetor/public_html/library/language/ru/main.php on line 1461 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Moscow' for 'MSK/3.0/no DST' instead in /home/w/wfb7902q/lifetor/public_html/library/language/ru/main.php on line 1461
в php.ini временную зону нужно настроить, на форуме обсуждалось как.
